Just did tune up. Everything is set factory dwell and timing etc. If I go WOT it will kinda sputter and not run great. I let off for a bit and then go WOT again and it runs fine. Any clues? Fuel/Water separator?
Check the anti sipon valve on top of the fuel tank. It is an 90 elbow that sits on top of the tank. Take it apart and clean the screen. Fixed my WOT problem.
