Ballast Sending Units
  • leesnuts
    • Aug 2005
    • 11
    Does anyone have a source for new ballast sending units. I have a '99 Super Sport with the factory ballast tanks, and both sending units are bad. SECC wants $160 per ballast sender, I have check both gauges (by disconnecting and grounding the sender wire) and they seem to be working. They say the senders are 10-240ohm, which is the same as early ford fuel senders. I didnt know if anyone has found an alternative to the expensive senders. I cant see any manufactures name on either sender. Thanks for the help, Newbee :grin: Nautique Owner
    -Lee
  • magene
    • Feb 2005
    • 88
    Any info?
    Lee
    I've got the same problem. Have you learned anything yet?
    Gene
    • leesnuts
      • Aug 2005
      • 11
      I wish I had, I really dont want to spend $320 for two sending units. Anyone??
      • lbz99smp
        • 55
        lessnuts.
        we've got a faulty sender unit in one rear tank in our SAN. I've tracked down the compnay that makes them.... well on ther website the look identical. I've sent them an email but they havent got back to me as yet...... that was amonth or so ago.
        heres the link
        http://www.wemausa.com/tank_sensors/...el_sensors.htm
        maybe you have more luck getting hold of them if your in the US......
        • leesnuts
          • Aug 2005
          • 11
          It looks like we can buy them online at $40 each, Sounds like it might be worth a shot. I will let you know what I find out.
          Lee
          • AirJeff
            • Jul 2004
            • 168
            • White Bear Lake, MN
            Did you guys try out one of these? Did it work and which model did you order. I've got one sender that is bad and I need to replace it. I'd love to have the parts ready when I take apart the boat so I don't have to miss time on the water!
            Jeff
            2002 Air Nautique (DD)
            GT-40
            • leesnuts
              • Aug 2005
              • 11
              Yep, mine are in and working great. I dont recall what model they were, they are sold by the length. I believe they ar 6"-8" in length. Now I found out how bad my valves really are. They let in quite a bit of water even when they are closed. Does anyone have a fix for them?
              • richard
                • Feb 2005
                • 406
                • HK
                Sender rebuild
                If you can solder,rebuild it uder US 10-20
                must take care to use good sealent since most problem is water leak to inside.
