Camshaft
  • 83sn2001
    • Mar 2005
    • 151
    • belmont, nc
    Camshaft
    Anybody have grind #'s and companies that make RH rot camshafts. What I plan to do is put GT40 heads and Edelbrock performer intake on a stock bottom end. It is an 83 2001.Thanks in advance
  • AWhite70
    • 29
    RE: Camshaft
    Comp Cams will make a RH rot camshaft. If you call them with your engine specs they will recommend a grind. I have grind numbers at home I can give you but I'm currently traveling, if you email me at awhite@cfu.net and remind me I'll send them to you.
    Just a caution about Comp Cams, it took them three tries to get my cam right. The first 2 times they swapped the intake and exhaust lobes. The third time they got it right and they assured me they'll never make that mistake again...My advice if you order a cam from them make sure you measure it.
