When I clean the engine with garden pipe I see water flow out along with the prop shaft, any member experience this ,is this normal? appreciate some body can answer.
RE: why water out there
If you have a dripless packing seal, some of them have a water hose going to the seal to cool it.
If you are not introducing water into the bilge, then the water is coming from the hose attached to the dripless packing gland. If you had normal wax packing and you were flowing this much water, you would be taking on huge amounts of water when you used the boat.
Also, where is the raw water inlet grate?
I beleive this is normal. You are flushng with fresh water and the packing is one place you would want to flush. Is there water flowing into the bilge? I would guess there is not. If that s the case this is normal.Nautiqueless in San Diego
Normal (I guess) for dripless, water cooled (via raw water pump) packing. Not normal for old school flax packing.
Richard: If water does not come into the boat, why are you concerned? Are there other problems with the stuffing box?
