I am taking my boat down to White Lake next week to have a heater installed. I have (or will have) the heater, so I am just trying to figure out how much the installation should set me back. It is the standard Heatercraft heater that comes with Super Airs with that option. I assume they'll need to remove the windshield and/or the dash to mount the defroster vent. Has anyone had one installed before?
How much $$ to install a heater in a SAN?
Jeff it is about 2 hours to install one without the vent and about 3-3.5 hours with the vent because they have to remove the windshield. Hope that helps!
SN:
Your time estimates were right on. I had it installed by White Lake Marine last week, and ended up being charged for about three hours labor. I had the heater installed (with defroster vent), had my tracking fins replaced under the recall, and had my shifter adjusted so that it would engage reverse properly (warranty as well). I can't wait for spring...
Now if I can just add the flip-up driver's seat...I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Glad to hear you are all set up. Now you are going to have to pay extra to have the heater winterized! Did you get your relay connections checked out?
Originally posted by skinautiqueDid you get your relay connections checked out?
Wait a minute... Is what you're talking about the same as the 5.0/5.7 Wiring Recall by PCM? I did hear about that, but I didn't have it checked out. Do you have details on how I could check it myself?I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
This is different than the wiring recall. That recall is to physically replace wires for the engine. The one that I am referring to involves your three sets of relays on the engine. Your dealer should be looking for this stuff to make sure it is taken care of. You just have to pull apart all three relays and make sure that all of the pins are making good connections. If not, you just use something that you can put in there to push the little tab over to make a better connection. I would just call White Lake and see if they took a look at it or not. Otherwise, it takes less than 5 minutes.
