Ballast Tanks Leaking????
  • GAnautique
    • Aug 2005
    • 33
    Is any else seeing water in the bottom of their boat after filling and emptying the ballast tanks?
  • richard
    • Feb 2005
    • 406
    • HK
    RE: Ballast Tanks Leaking????
    It's diffcult to see hvae water from bllast or not, because the leaking water will mix the billgie water and confuse, If you think tank leak,take out ,add detetgent and make bubble,than inlet pressured hose water,easier to check.
