I have a 2003 Super Air 210. I have been stranded and towed in twice over the last couple of weeks. The boat runs while unloading from the trailer, then dies when pulling a boarder. It then will not restart until the start button is cycled several times. I can get the motor restarted but then it dies again. I tried draining the fuel control cell to remove any water that may have been in there. The same problem persist. Any Ideas?
A d m i n i s t r a t o r
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
RE: Fuel Pump issues on 2003 Super Air 210
Have you tried changing the filter element? It might be clogged. Just a guess.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Sounds like the exact problem that we had. I thought it was fuel related, and turned out to be what I call the relay connections. They are located on top the motor when looking to the rear, they are on the front left side. I believe the Correct Craft put out a bulletin on this problem. A small amount of electrical grease on the right connection can fix the problem. I could actually move mine and it would stall the engine. Same thing when it would die out, I could move the connection to re-start. My dealer worked me thought the problem when we were on vacation. After vacation I took it to them, they made some sort of adjustment to the connections and never had the problem again. I was glad to have the problem fixed quickly, at first I was afraid I would be chasing a ghost. Good luck. You situation sounds exactly the same. Let us know what you finally find the problem to be. I'd bet $ it's one of the relays.2007 210 TE - Maiden voyage 4/25/2008!
2003 Super Air Nautique all white/blue stripe
2002 Super Air Nautique white hull/red & black stripe
1990 Ski Nautique grey hull/red & black stripe
1987 Ski Nautique cream hull/blue stripe
1984 Ski Nautique grey/black & grey stripes
1984 Ski Nautique biegh/brown stripes
1977 Ski Nautique white/blue letters
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
Here's a link to the recall notice about the relays.
Recall - Relays (2002-2003)I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Yep, It is the relay connections. If I touch one of the relays the pump starts running. One of the terminals looks a little burnt (very slightly). I bent this one to make a better connection and it seems to have fixed the problem for now.
If it is getting hot enough to open the reseptical it must not be sized correctly for the electrical load. Unless the load is high for some other reason.
I read the Recall attachment you sent and it says it is for the charging system. Also says it came out in 2002. Is there a recal for the Wire Harness or the harness plugs in 2003?
Great.... I thought for sure the relays would be the problem. I don't think that Correct Craft ever had a recall on the relays. It was just a bulletin explaining the problem. A little electrical grease on the connection you found may provide a little better connection.2007 210 TE - Maiden voyage 4/25/2008!
Had the same problem on my 97 ski. Moving one would cause the other to kick in causing the fuel pump to start. Crazy!2008 Super Air 210 Team
2004 AIR 206 Team
1997 Ski Nautique 196
1993 Ski Nautique SNOB
