Transmission problem
  • efox
    • 237
    • Lawrenceburg,In
    Unfortunately you have to use a vacuum pump to suck the fluid out. You won't get it all, but you will take more of the water with each change. Pump out the fluid, add the same amount back in, run the tranny a bit, check for the consistancy, change again if it's still milky.
    Eric Fox
