Oil change question
  • nelbird
    • 19
    • Hudsonville, Michigan
    Oil change question
    Hello, I am about to change the oil on my 89 ski nautique and have one question. Do you let the motor heat up and then change it or do you do it wile it's cold? I also wanted to say thanks for all the great info people have given me on other post. The people on this site are awesome.
  • SNMike
    • 1001
    RE: Oil change question
    Always change the oil when the engine is warm. :grin: Mike
    2007 Ski Nautique 196 Limited/ PP/ Mods
    • jhiestand
      • 778
      • Columbus, Ohio
      • 08 Super Air 210
      Conventional wisdom is to change oil when it's warm so it flows out quicker and more thoroughly. However, even steaming hot the oil comes out of my GT40 through the quick-drain at an unbelievably slow rate. So slow that even right after an entire morning on the river it still takes well over an hour for my pan to drip out. I've since resorted to using a drill pump to drain my oil and even when it's cold, I get more oil out than I ever did when I let it drain by gravity.
      Bottom line -- a pump will allow you to drain oil while cold. Now, some engine guru might correct me with a different reason you should do it while hot, but if it's just to get the oil to drain more quickly a drill pump will do the trick even when cold.
      '08 Super Air Nautique 210
        • 2908
        Never used a pump, always drained em warm.
        • 83sn2001
          • Mar 2005
          • 151
          • belmont, nc
          One tip when draining. Make sure the hose is pulled all the way through the drain hole. If not it may have a dip in the hose and cause slow draining. My 83 and every other boat I have owned have taken about 15 - 20 minutes to drain because the ID of the hose is smaller than the drain hole in the pan. If you are winterizing it a great time to take care of other things while the oil is draining.
          • 97sport
            • Mar 2005
            • 78
            • Youngstown, Ohio
            Oil change question
            always drain the oil when it's hot. not only makes it faster but it also suspends the inpurities in the oil itself.
            • slob02
              • Sep 2003
              • 333
              Remember to put the cap back on.
              If you really want to get all of it out ........let it drain over night. Warm oil does go a little faster, but not a lot.
              2008 Super Air 210 Team
              2004 AIR 206 Team
              1997 Ski Nautique 196
              1993 Ski Nautique SNOB
              • surroundsound64
                • Jul 2005
                • 2147
                • Longview, TX
                • 2018 230 1981 Ski Nautique
                It comes out real fast when it gets diluted with gas because your fuel pump diaphram breaks!!! :grin:
                :evil:
                At least I got it taken care of relitavely quickly. hehe.
                2018 SAN 230
                1981 Ski Nautique
                Sold - 2011 Sport 200V
                Sold - 2000 SAN
                • jhiestand
                  • 778
                  • Columbus, Ohio
                  • 08 Super Air 210
                  Can't beat using a pump. I had to buy one to change transmission fluid anyway, and it works like a charm on oil changes, too. Using a pump gets nearly a qt more oil out than I ever was able to get out gravity draining, regardless how long I let it drip.
