Just wondering what the compression should be on a 1997 Gt-40 EFI
RE: what should compression be
Are you eagledriver from mbo?
http://www.correctcraftfan.com/ftp/new/PCMsvcmanual.pdf see page 138, 105-140psi. It is not specific to GT-40 but I believe this applies to almost any V8 since I have read almost the same thing in a Chilton's for a Chevy truck motor. Higher compression engines should have a slightly higher reading. The new Chevy's have 9.4:1 compression, the manual specs are 130-160psi.
I thought the GT-40 manual was somewhere on the site but I didn't see it. I gave mine to the buyer of my 1995 thinking I could print another anytime.
Re: RE: what should compression be
Originally posted by MikeskiI thought the GT-40 manual was somewhere on the site but I didn't see it. I gave mine to the buyer of my 1995 thinking I could print another anytime.
http://www.planetnautique.com/index....q=getit&lid=22I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Somewhere along the way while I was checking out used boats to buy I read (or was told) that the compression needs to be not only in the range mentioned above but all cylinders need to be within about 5-10 psi from the lowest reading to the highest reading. Made sense to me as a wide range would indicate uneven wearing. I bought a 2000 SAN with all readings within 5 psi and am very happy so far (knock on wood).
Hope this helps - Gene
