Fog the Engine?
  • jedgell
    • 170
    • Bozeman, MT
    • 2004 SN 196
    Fog the Engine?
    About to winterize my boat tomorrow, how important is it to fog the engine? I know a lot of people that don't do it, but the manual says to. What are your opinions on the benefits, or lack of, to fogging.
    \'95 SN Signature Ed.
    GT-40
    PP Stargaze
    **For Sale**
  • fyerfytr
    • Jun 2005
    • 83
    • Des Moines, Iowa
    You have to winterize in Texas? I will trade ya for a Iowa winter :grin:
    I removed the spark arrestor and sprayed some in till it started running kinda crappy then shut it off - that should be good enough.
    I would say it is probably a good idea. Just to keep everything lubed up and the seals from drying out.
    I put mine up last week and am missing it already, it will be a long winter for us.
    • jedgell
      • 170
      • Bozeman, MT
      • 2004 SN 196
      Fyerfytr,
      I'm moving to Montana next week, will be towing the boat up behind the Uhaul, that's why I'm winterizing. Thanks for the input, I guess I'll fog it.
      GT-40
      PP Stargaze
      **For Sale**
      • pj
        • Oct 2003
        • 323
        • Rochester, MN
        • 1991 SN 1996 SN
        On my '91, with the carb, I remove the spark arrestor and spray it in like fyerfytr said. On the '91 and the '96 I remove the spark plugs and spray some fogging oil into each cylinder, then I replace the spark plugs, but not the wires, and give her a couple of cranks to get the cylinder walls nice and coated.
        Once you have tasted flight, you will forever walk the earth with your eyes turned skyward. For it is there you have been and there you will long to return. - Leonardo De Vinci
        • M3Fan
          • 1034
          I don't remember the specifics but I recall a post or two about the GT40 being a dry intake and having stainless valves and such, and that fogging wasn't necessary/reccommended. Again, it just rings a bell in memory- don't know the specifics- EFI is not my specialty!
          2000 Ski Nautique GT-40
          2016 SN 200 H5
          www.Fifteenoff.com
          • jhiestand
            • 778
            • Columbus, Ohio
            • 08 Super Air 210
            Your manual says to fog your GT40? Interesting, as mine says not to. Well, the winterizing instructions say to fog the cylinders individually and crank the engine by hand. There were a few threads on this but I think the bottom line was fogging a multiport fuel injected engine usually isn't recommended.
            That being said, I think earlier GT40's were TBI?
            '08 Super Air Nautique 210
            • Jesse1
              • Sep 2004
              • 78
              • East Texas
              I've never fogged my EFI engines. I add fuel stabilizer to the tank and run the engine. Change the oil while it's warm and run it again to circulate the fresh oil. Then I drain the block and pull the raw water impeller. Fill the block up with non-toxic antifreeze and water and wait for spring.
              • SGY
                • 990
                The GT-40 intake is considered dry by PCM. Something about a MAP sensor that doesn't react well to fogging oil. On my Excalibur, the manual says to remove the spark arrestor and fog the motor by spraying into the intake. That makes it easy.
                I hate to winterize my boat. Kind of depressing. Our winter is going to be long here as well.
