I have an 89 SN. I want to upgrade my push button switches to a lighted version. I'm trying to design a new dash for my boat. I want to put on a new teak dash. Where can these new switches be purchased. Thanks.
Tags: None
RE: Lighted push button switches
I have a complete set of rocker switches out of an 02 Air. They are like new - I installed the pod switch panel / keyless ignition.
New switches from CC are $27 a piece.
KP
BE CAREFUL! Those are circuit breakers, not switches! If you put in regular lighted switches, your circuits will be unprotected against overload. I don't know of a source for lighted circuit breakers. If you go with switches, make sure you put circuit breakers or fuses of the appropriate size somewhere downstream of the switch.
