low RPM heater fix??
  • AirJeff
    • Jul 2004
    • 168
    • White Bear Lake, MN
    On a GT-40 can you could hook one of the heater lines to the drain on the bottom of the engine water pump elbow? Would that give us heat at low RPM's? Right now the heater is "T'd" at a temp sensor (port side) and the other hose runs to the starboard block drain. Does it matter which hose I move to the elbow? Thanks!
    Jeff
    2002 Air Nautique (DD)
    GT-40
  • mlange
    • 90
    • Oconomowoc, WI
    • 2012 SN 200 Mapple Icon Edition
    Jeff,
    Heatercraft has a fix for this. They have a Y-adapter that you can get from them for around $25 that is installed before the raw water pump. Call Heatercraft and they can help you out.
    There's a picture of it in this thread:
    http://www.themalibucrew.com/forums/...eatercraft+fix
    Mike
    • M3Fan
      • 1034
      Just be sure to ask for the 1" ID version.
      2000 Ski Nautique GT-40
      2016 SN 200 H5
      www.Fifteenoff.com
