Integrating custom ballast to key pad on 2003 SAN
  • Brownie
    • Jun 2004
    • 87
    • Nowra/Taree NSW, Australia
    I am going to plumb a fatsac in the belly locker of my 2003 SAN. I was wondering if anyone could help me.
    I would like to use the "Belly Ballast" button on the keypad to control a Jabso impeller pump that I will change the polarity on to fill / empty via a skin fitting on the transom.
    Is this possible to do this with the keypad button, or should I just keep it simple and use a three position toggle?
    Brad
  • ihaveansv211
    • Oct 2005
    • 164
    • New England
    RE: Integrating custom ballast to key pad on 2003 SAN
    u should be able to use that button as just the switch for it. of course its not going to power the pump so u will have to hook ur pump to a source of power and then u can run that power line to the belly ballast button. i have my tower lights wired to it like that and it works fine. a few other people i know run that setup too so u should be ok
    www.shredcandlewood.com
    • Roddbod
      • Sep 2004
      • 116
      Brownie,
      I did this exact project on my 04 SAN, but insteat of using a jabsco pump I used the areator pumps that are similar to the ones that came stock on my back tanks. I also purchased the helm controls because I added another water pickup.
      The wires are probally already run fo you. On my 04 they were just zip tied up so they werent hanging. The only problem I see you having is that the stock wires are are already run are not going to be heavy enough for that pump. The pump you want to use draws a lot of power. I will post some pictures of my install when I get home tonight.
      • Brownie
        • Jun 2004
        • 87
        thanks for the replies guys. I haven't looked at the back of the key pad yet. Where abouts did you connnect the new wires, are they at the key pad or somewhere else? I haven't played with anything yet.
