Hi Guys
MY 2003 SANTE was used for the recent AsianProtour in Phuket Thailand.
On the first day, Friday, everything worked fine til the afternoon when boat overheated and was in limp mode.
On checking this out Sat morning, found out no water in the water filter whose metal strainer had a greenish algae covering it ...hence the restriction of water flow.Boat not picking up water? surely it was an impeller problem and on opening the raw water pump, true enough impeller was burned out.Managed to recover 4 or 5 of the blades and i know there are 4 or 5 still in the engine's cooling system.Installed a new impeller and boat ran great all day Sat and Sunday until the final event and ....overheat and limp modeyet again.
On checking this again, noticed water filter not properly screwed back on, hence air intake, hence problem.
Funny thing is, now the boat is not picking up water when it is sitting on water, even with a new impeller.I have checked all hoses for leakages and restrictions.
When the boat is on the trailer, engine runs fine when garden hose with running water was stuffed into the water filter.Guess so since there is water pressure.
Does the engines water pump have an effect on all this???
