anyone know of a source for these switches as $50 each seems a bit expensive to me.
RE: Switch
Shouldn't that boat still be under warranty?I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Re: RE: Switch
Originally posted by NautiqueJeffShouldn't that boat still be under warranty?2007 Ski Nautique 196 Limited/ PP/ Mods
RE: Re: RE: Switch
I am the third owner and the boat was bought into Australia before we had a dealer network as a promo boat. Warranty might be a bit of an issue.
This is the switch / button that sits just underneath the engine hatch on the transom. it unlocks the side stogare lockers.
Switch / Button on rear lockers of 2003 SAN
Do you have access to a Cole-hearse catalog or something allond that line,because you may be able to match it up or have something close to fit in it but make sure it can handle up to 30 amps.
RE: Switch / Button on rear lockers of 2003 SAN
Brownie, I know this obvious, but make sure that the wires are still on the switch. I believe that the wires are just a crimp-on connector, pushed on to the switch. I would check the continunity should be checked in every thing before I spent $50.00 on a switch.
I have taken the horn switch apart on my 1997 Ski Nautique to clean the contacts.
