accessory/shower wire in a 06' 210
  • TwinTip
    • May 2004
    • 294
    Looking at the PP display on the picture above, this may be an '05 instead of '06. The '06 comes with the larger display on the PP.
    • jhiestand
      • 778
      • Columbus, Ohio
      • 08 Super Air 210
      I wouldn't be the least bit suprised if the pix on their website weren't up to date or 100% accurate.
      '08 Super Air Nautique 210
      • awake4air
        • 129
        • CA
        On my 06' 210 it has a picture of a shower on the button even though the manual calls it an accessory switch. I did some further investigation of the wire harness and found out that they did not include the wires in the harness. If you look at the main wire harness coming off the panel, the wire is missing from the 40 pin connector. I looked at the diagrams from the 05 wire harness and was able to determine the correct pin location for the shower. Although the wire isn't there, I was able to test the pin with a multimeter to verify it shows 12v when you hit the shower/accessory switch. I'm going to add my own wire.
