Pylon removal
  • jschofiel
    • Jan 2004
    • 9
    Pylon removal
    I am starting a recarpeting projet on my 99 SN and now ready to remove pylon. I have loosened both U-bolts, I can rock pylon fairly easily port-starboard, but it is too l tight to lift out. What am I missing?
    Jay Schofield
  • Frost
    • 161
    RE: Pylon removal
    The U-Bolt on the bottom needs to be removed to get the pylon out, the top two can just be loosened
    • wviveen
      • Dec 2004
      • 133
      • Santa Monica
      • 2016 Nautique G23
      RE: Pylon removal
      I just removed the pylon from my supersport and had the same problem.
      First try to remove the top 2, which should go fairly easy. That will give you enough room to remove the bottom one. I took me quite some time moving it around, but finally it worked.
      good luck.
      • Frost
        • 161
        RE: Pylon removal
        The bottom U-Bolt is smaller than the other two and lock into the pylon at the bottom, the bottom bolt will have to come out completly and loosen the top 2 bolts
