2000 Pro Air Starts and than Stops
  • sterling.abel
    • Jan 2005
    • 2
    Was wondering if you could answer a question in regards to a 2000 Pro Air?
    I understand an open kill switch will cause the boat to start and than die after about 3 seconds. What other common problems can be traced to that? Jumping out the kill switch is easy. I believe a bad fuel pump or its pressure switch would cause the same thing? What other tests can be done to isolate the problem?
  • Labatt911
    • Sep 2004
    • 110
    • NE Ohio
    • None Currently : ( 1999 Pro Air 1998 Sport/Air
    RE: 2000 Pro Air Starts and than Stops
    If the engine is fuel injected change the fuel filter in the FCC.
    ** Be Not Afraid **
