Need help - After installing another amp - I have NO power to the faria gauges :shock: . Everything else works fine. I can not find any problem. Does anyone know what might fix this or where to start looking? Nothing works. No tach, speedometer, fuel, battery, etc.. Perfect pass lights up like normal and all features from the keyless pad work fine.
RE: HELP - No power to Faria Gauges
Can't help you there, the only fuses I know of are up under the dash, mounted on the kick wall, and I thought they would reset once tripped?? -- You might want to check your manual if you have one or check this link http://www.planetnautique.com/index....iewtopic&t=367
Good luck1973 CC Skier
1989 SN 2001
2002 SN 196
2005 216 Limited
did you nick any wires or disconnect them from anywhere? Kind of odd to not even have power at the battery. Do you have a good connection at the battery?
Re: HELP - No power to Faria Gauges
Originally posted by geoffc210Need help - After installing another amp - I have NO power to the faria gauges :shock: . Everything else works fine. I can not find any problem. Does anyone know what might fix this or where to start looking? Nothing works. No tach, speedometer, fuel, battery, etc.. Perfect pass lights up like normal and all features from the keyless pad work fine.1973 CC Skier
1989 SN 2001
2002 SN 196
2005 216 Limited
I don't believe I nicked any wires or disconnected anything on accident. I did disconnect the power and ground wires going to the "brain" box and did see 12V going to the unit. However, nothing is powered at the dash (except for the keyless ignition, stereo and PP). I am worried now that I might have "fried" something internal. I am going to try and call Faria and my dealer today and work on this some more.
I did remove the kill switch and forgot to reinstall. I was hoping this was the problem, but still no power at the dash. Would this have tripped something that needs reset? Everything else works on the boat except the gauges.
Does anyone know how I can check one of the gauges wires to see if there is any power at the gauges?
I have an 01 pan... dont know if the 03 is the same... but my large white/clear plastic 9 or 12 pin connector is definately not aircraft quaility... try disconnecting it and reseating... add some dielectric grease to that connecton if it has corrosion.. it sounds like your not getting a good ground or power to the insturments... probably just a bad connection... power is fed via a relay... from the cb box...2001 PAN 1995 ramlin single axle
