Starter motor pcm 2012 5.7 400 hours
  • laurie8888
    • Dec 2011
    • 162
    • dubai
    • nautique 206 and 200
    Guys
    Went to start boat and heard click from starter motor boat won't start but all lights on ignition ok boat does not turn over
    Battery is full charge
    Do I need to replace starter motor or could it be a starter relay
    Tx
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    It worked perfectly up to now? Are batteries fresh? Is the relay a match to other relay's? I can't remember. You could take starter out and take in to any auto shop to test. Or you could research how to bypass relay while still installed in boat.
    • LakeRats
      • Jun 2012
      • 50
      • North Carolina
      • 2012 Sport 200V
      Check connections to both battery terminals. Remove, clean and tighten them. Check connection negative engine block. Check connection positive to starter. Hook a volt meter to the starter connection and ground, check voltage to starter when trying to start. Many times it is a loose or poor connection somewhere.
      • laurie8888
        • Dec 2011
        • 162
        • dubai
        Checked and cleaned starter bit of corrosion on it cleaned all Neg connections seems to working now grT
