01 SAN vibration after change strut
  • richard
    • Feb 2005
    • 406
    • HK
    Bad luck today, test the boat to sea after change the strut, though that will make more smooth,but, vibration come out, no matter idle or fast, before not like that, so think not by prop or shaft, test on trialer, and engage to turn the propeller, some unconstant "kick' sound heard, trace the souce seems inside the vdrive near the shaft coupler, the boat don't use for about 3 month in winter,even run the engine sometimes during winter,but the gear not engage, (next time run the engine better run the transmission also), now I think something wrong w/the vdrive, seed for advise or experience for this issue, the boat used 500hr,PROBOSS VDRIVE 1:1
  • richard
    • Feb 2005
    • 406
    • HK
    after study some similar thread,I found may be related to 2 parts: bearing and damper,will appreciate if some experience about damper or bearing ng will cause vibration/not smoothing running?
