Resetting computer
  • NAWTEAK
    • Aug 2005
    • 192
    • Orlando
    Resetting computer
    Does anybody know how to reset the computer on a 06 210? the dash alarm keeps going off, reading "ignition fault, see dealer"
    now before you say take it to the dealer, it was them who set it off when they were testing the engine. Aparently there is some sort of procedure to reset it, but they didn't know. i'd driven 2 hours to pick the boat up so i wasn't going to leave it there, plus they were pretty clueless.
    Cheers
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    RE: Resetting computer
    I'm not sure how CC or PCM has it set up, but with a lot of cars if you disconnect the battery for a certin number of hours it resets the computer. It might be worth a shot, and definatly worth a shot before taking it to a dealer.
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • MHayes
      • Aug 2004
      • 830
      • Roswell, GA
      If the dealer set it off and doesn't know how to reset it, I think I'd find another dealer. Sorry, for not offering a solution, but that is just crazy. Good luck.
      2001 Air Nautique
      • surroundsound64
        • Jul 2005
        • 2147
        • Longview, TX
        Definately.
        2018 SAN 230
        1981 Ski Nautique
        Sold - 2000 SAN
          • 2908
          He is in Australia, not many options...
          • ihaveansv211
            • Oct 2005
            • 164
            • New England
            i dont think u would need disconect the battery, pulling the fuse for it would probly do it. keep the fuse out for like 20 seconds and see if it works
            www.shredcandlewood.com
            • surroundsound64
              • Jul 2005
              • 2147
              • Longview, TX
              Ya, anything that opens the circuit. Not limited to pulling a batt. connection.
              2018 SAN 230
              1981 Ski Nautique
              Sold - 2000 SAN
              • NAWTEAK
                • Aug 2005
                • 192
                • Orlando
                thanks,
                disconnecting the battery did not work. i will try the fuse
                • krs0394
                  • Jan 2006
                  • 170
                  • Sturgis, MI
                  email Mid-west correct craft @ mwcc@nautique.com -- They will be able to answer your question
                  1973 CC Skier
                  1989 SN 2001
                  2002 SN 196
                  2005 216 Limited
                    There is a way to do a reset, and pull the codes wirh a paper clip. and a test light, but I do not know the specifics of the procedure. You might be able to do it with an ODB-II scan tool, but I do not know if that is available in Australia. You might try contacting PCM directly.
                    • NAWTEAK
                      • Aug 2005
                      • 192
                      • Orlando
                      you are correct. i got some really good feedback directly from Correct Craft. Everything but the exact procedure. that **** beeping sound is pretty annoying, but hopefully sort it out today.
                      thanks
                      • surroundsound64
                        • Jul 2005
                        • 2147
                        • Longview, TX
                        you are correct. i got some really good feedback directly from Correct Craft. Everything but the exact procedure. that darn beeping sound is pretty annoying, but hopefully sort it out today.
                        thanks
                        If nothing else works, a hammer has never let me down. Yellow_Flash_Colorz:
                        2018 SAN 230
                        1981 Ski Nautique
                        Sold - 2000 SAN
                        • derby
                          • Jul 2005
                          • 58
                          Hmmm I was just thinking about this yesterday. Do the new boat motors come with a OBDII scan port?
                          • derby
                            • Jul 2005
                            • 58
                            By the way, pulling the neg. off the battery is the same as pulling the fuse, provided the fuse is the one to the computer. On a car at least.
                            • surroundsound64
                              • Jul 2005
                              • 2147
                              • Longview, TX
                              As I said earlier, anything that opens the circuit.
                              But Nawteak said he tried it and it didn't work.
                              2018 SAN 230
                              1981 Ski Nautique
                              Sold - 2000 SAN
