WALTER V-DRIVE problem
  • richard
    • Feb 2005
    • 406
    • HK
    Trace today the noise/vibration found very likely the kicking noise is from the WALTER v-driver near the shaft coupler, confirmed the v-drive need repair or replace, appreciate if some body would share experience to repair; steps to disasemble/ soure for new one/parts supplier.
  • wakejunky
    • 679
    • Ca
    • 2003 SAN
    RE: WALTER V-DRIVE problem
    Call up West Coast Correct Craft and ask for Mark Rhodes. He has a source in the bay area which is supposed to be reasonable.
    http://www.westcoastcorrectcraft.com/about.html
    Chris
    • richard
      • Feb 2005
      • 406
      • HK
      which part NG?
      took out the engine and tranny w/v-drive,opened v-drive bottom cover and have a sight check and hand rotate the gears,can turn smooth, seems no problem,now also thought caused by transmission ng? I think the way to solve the problem should change one gear box,v-drive or transmission? appreciate to hear some experience of this.
