Fuel Cell Leak - Suggestions?
  • SCNautique210SAN
    • Mar 2011
    • 194
    • SoCal
    • 13 G23 04 SAN 210TE 92 Sport Nautique
    Hey guys,
    Went to replace the filter in my fuel cell on my 2004 SAN 210, put it all back together and realized it was leaking through the power leads that run through the cell to the pump. They make a repair kit but it's on back order for an unknown amount of time. Has anyone found a work around to seal the wires that run through the top of the fuel cell to the pump?
  • jhersey29
    • Nov 2013
    • 330
    • Colorado
    Call PCM. They will send you one and a fuel filter. You will just need to send back the old electrical connector. Ext. 108
    • jhersey29
      • Nov 2013
      • 330
      • Colorado
      You'll also need a dremel or angle grinder to cut off part of the bracket that covers the hole for the connector. The new ones are brass, taller and larger in diameter.
      • SCNautique210SAN
        • Mar 2011
        • 194
        • SoCal
        Thanks jhersey, I called them today and they are sending me one this week!
        • jhersey29
          • Nov 2013
          • 330
          • Colorado
          PCM rules! They care about us. If only Ford would make the 351w again.
          • jhersey29
            • Nov 2013
            • 330
            • Colorado
            I did this repair in 2 nautiques this year. Cover your alternator. It is a little bit magnetic and will grab the shavings from cutting the bracket. I ended up using a magnet to pick up the cuttings since I didn't know about the issue the first time and forgot the second.
            • SCNautique210SAN
              • Mar 2011
              • 194
              • SoCal
              Thanks for the tip! Yeah I almost bought one for $85. Thankfully I called pcm first. Decided to do a pump and filter too while it's apart. Only has 350 hours but it's 10 yrs old now so might as well. I had to get the biggest monkey wrench to pull the thing apart! Broke a oil filter strap and didn't budge with one of the fixed oil filter tools!
              • jhersey29
                • Nov 2013
                • 330
                • Colorado
                Been there. Broke 3 oil filter wrenches this summer. Finally found 2 beastly ones and used them at the same time. Lesson learned.. DO NOT USE THREAD SEAL. The o ring or rings based on year are enough. Lube the threads and seals with motor oil should be good.
                • SCNautique210SAN
                  • Mar 2011
                  • 194
                  • SoCal
                  Lol definitely bought thread seal and would have used it. O ring looks to be in good shape so I'll probably re use it
                  • laurie8888
                    • Dec 2011
                    • 162
                    • dubai
                    • nautique 206 and 200
                    Sorry but this is related,,,,,,,,nautique 200. My fuel cell canister dropped from holding clamp whilst underway!!!!! Fuel everywhere and dangerous of course, anybody experienced this before . I changed out filter 4 months ago and have done this job before
