Sealing ballast tank on 2000 SAN
  • Byron
    • Jan 2014
    • 17
    • Raleigh, NC
    • 2014 210
    The cap on our 2000 SAN starboard side ballast tank is no longer air/water tight. So, it leaks when completely filled and I can't fill only the port side tank. I've taken it to a dealer with no luck. Any suggestions? (I wouldn't mind a permanent seal if someone knows the best way to do this, even if it meant could no longer replace the sending unit when needed.)
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    The trick is finding something that sticks to the plastic tank. I don't think standard bondo stuff works. If it was me I would try one of these:
    http://www.walmart.com/ip/Aquaseal-U...t-8oz/32313553
    http://www.walmart.com/ip/SHOE-GOO-1...18861/40830725
    http://www.walmart.com/ip/J-B-Weld-5...ringe/37572799
    • ddipert
      • Nov 2013
      • 116
      • Mebane NC
      • 2010 SANTE 230
      You will be better off using a plastic welder something like this:
      http://t.harborfreight.com/welding/p....google.com%2F
      I've repaired a few kayaks which are built like the tanks in our boats. It's easy to use take it easy and don't melt to much at one time.
