Oil and Trans fluid changes
  • 4th ski-doo
    • Apr 2013
    • 307
    • Wilmington
    • 2013 SANTE210 2011 Sport200V 1994 Bimini Skier 190 1986 Master Craft Pro Star 190
    I am a do it yourselfer but have to ask where is the best place to find a pump that works on 12v small enough to mount on top of a bucket but strong enough to suck out the oils?
    2013 SANTE 210
    2011 Sport 200 V
    1994 Bimini Skier Pro 190
  • nukemustang
    • Sep 2014
    • 410
    • Summerville, SC
    • Current Boat: 2018 GS20
    Is there a particular reason you "need" a 12V version? I think most people just use the manual pump version you can get from overtons or west marine, its much cheaper when you catch them on sale. Amazon has both manual and 12V ones, but it seems the 12V ones usually get "poorer" reviews.
    http://www.westmarine.com/buy/west-m...uart--11047123
    • 4th ski-doo
      • Apr 2013
      • 307
      • Wilmington
      I hit google and found this, for $33 I'll give it a try
      http://www.iboats.com/Service-Kit-Ja...X48aAu7g8P8HAQ
      2013 SANTE 210
      2011 Sport 200 V
      • d_nodixon
        • Sep 2008
        • 475
        • Hammond, LA
        • 2013 SAN 230
        I use one those pumps you can run with your cordless drill, works great, takes some hand eye coordination to not make a mess, but works great
        2013 SAN 230
        2006 SSN 210 (SOLD)
        • Nautiquehunter
          • Jun 2008
          • 2080
          I just ordered the one from Iboats Ill let you know how it works.
          • nukemustang
            • Sep 2014
            • 410
            • Summerville, SC
            I hope that is what it is. If you google that, the list prices come up at about $200. If that is really what you get, please let us know, cause it would be one of those deals of the year!
            http://www.google.com/shopping/produ...ed=0CCAQ8wIwAA
            • scottb7
              • Aug 2011
              • 2198
              • Carson City, Nevada
              Yikes, that would be a good deal. I think the $33 is just what it says, "service kit." It is an o ring and a impeller. http://www.amazon.com/Jabsco-90061-0.../dp/B00CXG875E
              I tried one of the drill pumps back a few years ago and could not get it to prime. I use hand pump to the remote hose end and love it. Whole oil change is maybe 30 minutes or less.
              • 4th ski-doo
                • Apr 2013
                • 307
                • Wilmington
                The one from iboats is only the repair kit, went back and read it after hooking up the link. I did order this one from Discount Marine tho, still around the same price as the hand deal but has a nice container to try eliminate messes.
                I wanted an electrical pump to drain the trans better, that calls to be changed almost as much as the oil in the manual! What fluid is it tho? not listed in manual.
                http://www.discountmarinesupplies.co...ge_System.html
                2013 SANTE 210
                2011 Sport 200 V
                • nukemustang
                  • Sep 2014
                  • 410
                  • Summerville, SC
                  Its listed in the manual for the motor, PCM manual. I looked at the ones on the top of the site here for '13 it was on page 28 of the .pdf. I am not sure what transmission is in your boat.
                  PCM Dexron III Automatic
                  Transmissions Transmission Fluid (ATF)
                  or equivalent
                  PCM V-Drive Mobiltrans SHC 50
                  Transmissions Synthetic Transmission
                  Lubricant (R190250)
                  Walters “V”-Drive SAE 30
                  All Hurth Gear Transmission Fluid (ATF)
                  Transmissions or equivalent
                  • 4th ski-doo
                    • Apr 2013
                    • 307
                    • Wilmington
                    Thank you, didn't think of the engine manual. Sometimes the obvious is obscure.
                    2013 SANTE 210
                    2011 Sport 200 V
