PP instal Quest
  • todda
    • Jan 2005
    • 281
    • Granite Falls, WA
    • 1999 SNOB
    PP instal Quest
    Anyone instal their own PP by replacing the existing Airguide spedo? PP recommends clamping the Airguide input, and I was wondering how most of you have done this. Would folding it over and tightly wire-tieing it work?
    Thanks!
    Todd
    Todd Aalbu
    1999 SNOB
    66.5" HO S2
  • G-man
    • Jun 2004
    • 428
    • Allen, Texas
    RE: PP instal Quest
    What model PP you using? The first models before paddle wheel used the pitot tube for trick mode. Now a days it uses the paddlewheel for for trick and wakeboard mode. Slalom is handled by rpms. If your pulling out a duel speedo put a golf tee in the hose and tiewrap it in an out of the way place that can get wet should it leak.
    Current
    2003 SkiNautique 206 LE Yellow - Black - Silver Cloud
    Previous Fleet
    2006 Ski Nautique 196 SE Titanium - Black- Silver Cloud
    2004 Ski Nautique 206 LE Red - Black - Silver Cloud
    1993 Mastercraft Stars & Stripes 190 Red
    • peteSki
      • Mar 2005
      • 232
      • Ottawa, On, Canada
      • 2005 Sport Nautique 216 Previous: 1997 Ski Nautique
      I installed 6.5N a few months ago into my 97 Ski. In addition to keeping the pitot in the up position for the speedo I removed, I folded the hose that I disconnected at the back of the speedo and then zip tied it twice. It's been 8 months now and no leaks. I also pulled the hose out from behind the dash and secured it to the steering assembly. That way if it had of leaked, it wouldn't have sprayed the electrical stuff on the nside of the dash but would have just got my feet wet.
      Pete
      • todda
        • Jan 2005
        • 281
        • Granite Falls, WA
        • 1999 SNOB
        Thanks guys. G-man, I am running a PP Plus w/6.5, so RPM's are really the only mode, no paddlewheel. I like the golf tee idea, I will try that. And Pete, good idea running it out from behind the dash module if ever a leak. Thanks for the input!
        Todd
        Todd Aalbu
        1999 SNOB
        66.5" HO S2
        • G-man
          • Jun 2004
          • 428
          • Allen, Texas
          Todd why aren't you installing a paddlewheel? They tend to be used for boarding and trick speeds.
          Current
          Previous Fleet
          • cat1168
            • Dec 2005
            • 73
            • Connecticut
            Installing the paddlewheel is not that hard to do. Yes it is a little scary to dill a hole in you boat but it really is not that bad. I did it to my 2000 Ski. It took me about 10 minutes of saying do I really want to do this before I did. It was a very good addition to the boat. Just make sure you get a very good boat grade sealer.
            • todda
              • Jan 2005
              • 281
              • Granite Falls, WA
              • 1999 SNOB
              yeah, G-man, I am planning on upgrading to the paddlewheel at some point. Right now, I use my boat primarily to ski, and so my first objective was to upgrade from my current PP basic cruise to the Plus w/timer, since I already have the RPM servo and basic master module that will accomodate this. Seemed like the easiest and least expensive way to upgrade to what I am looking for right now. Cat-yeah, I think that when I do finally instal the paddlewheel, I will be doing ALOT of measuring, praying, measuring (not all in that order!) Hey G-man, I am thinking that your pin should be G-McGyver with the whole golf-Tee trick!
              Todd
              Todd Aalbu
              1999 SNOB
              66.5" HO S2
