Has anyone out there done this and if so were you able to use the existing holes for the new lights? If not, how did you seal/repair the original factory holes for the wire and screws (2). Thanks
Jhelper,
Depending on the lights you are replacing the factory light with will determine what you need to do. At minimum I really doubt you will have to drill a larger hole for the new light wire. I know that my Lumitec S3 requires a 1/4" hole. I would simply remove the factory light and wire the new light accordingly. Then seal it up with 3M 5200 or equivalent.2008 210 SANTE
- Mar 2002
- 16462
- Lake Norman
- Mooresville, NC
That sounds like a great solution. Here's a shot of how mine were set up last year, and they were great! This is two 2" and two 6" Roswell Nightwater Pros.
Thanks Jeff. That looks like a great set up. I'm guessing you swapped out the stock Attwood lights with the 2" Roswell and used the existing hole for the wires right? Work looks good.....Race City or Whitelake? Any particular reason you went with the nightwatrer Pro as opposed to the L6 model? Just noticed the transom protector. I've got SeaDek teak on order and was wondering where you got the transom pieces from?
