02 or 03 SAN TE gauges?
  • smay1981
    • Aug 2004
    • 37
    • Plano, TX
    I'm in the process of looking at some SAN 210 TE, I was told that the 02 gauges are only digital, and the 03 have digital and manual like the new 06s.
    Is there problems with the 02s only having digital incase something goes bad. At least if the digital goes out in the 03 the manual is there to work. Just curious if any body has experienced any problems with the 02 gauges.
    thanks, Scott
    Scott
    Former owner of this 81SN
    Current owner of this 94SN
  • dave210
    • Jan 2006
    • 113
    • jax fl
    RE: 02 or 03 SAN TE gauges?
    I have an 02 that the speedo guage went out (the screen went black) actually just replaced it due to always using perfect pass. other than that everything has been fine
    • krs0394
      • Jan 2006
      • 170
      • Sturgis, MI
      I had an 02 ski -- speedo quit working within first 40 hours. :evil: Had a heck of a time finding replacements, back ordered on warrenty, finally replaced them with Feria anolog gauges. I have talked with others and they had same issues. If the gauges work ok, check to make sure the bezels aren't cracked. That was another issue with Digital
      1973 CC Skier
      1989 SN 2001
      2002 SN 196
      2005 216 Limited
      • AirJeff
        • Jul 2004
        • 168
        • White Bear Lake, MN
        Do a quick search on "Faria" and you will find a bunch of info on the '00-'02 gauges.
        Jeff
        2002 Air Nautique (DD)
        GT-40
        • Andrew
          • Aug 2005
          • 891
          • Tuscaloosa, AL
          do these newer gauges work from air pressure like the older ones, or a paddle wheel?
          • krs0394
            • Jan 2006
            • 170
            • Sturgis, MI
            I had the pick-up tubes removed on my 02 and just had them tie into the paddle wheel for the PP, but my 05 still uses the pick-up tubes and a seperate PW for PP. Not sure of the reasoning since a paddle wheel under the boat is much more effective and accurate IMO
            1973 CC Skier
            1989 SN 2001
            2002 SN 196
            2005 216 Limited
            • Andrew
              • Aug 2005
              • 891
              • Tuscaloosa, AL
              so could i use 02 gauges on my 86?
              • DRAGON88
                • 529
                • Eugene, Oregon
                • 1999 Sport Naqutique 2005 Super Air Nautique Team Edition
                You could use any gauges with enough work. Personally given all the troubles with the 02 Teleflex Gauges, if you're going to upgrade and spend all that time rewiring exc, I'd go for the newer faria analog gauges.
                How about \"Chales\"?
                RIP Nikolai (\'05 SANTE) 5/23/05 - 4/30/06
                • Andrew
                  • Aug 2005
                  • 891
                  • Tuscaloosa, AL
                  what i meant, was will they plug right up. how much trouble would it be to wire in the farias?
                  • mgaspence
                    • 81
                    replaced teleflex digital with analog faria
                    I bought '02 SAN. It came with digital gauges. They worked fine but when in the sun they where sometimes hard to read. And, they just looked modern. I preferred the more classic look of the analog dial with needle gauges. Faria has good replacements.
                    I installed paddlewheel with wakeboard pro and swithed out digital gauges for analog faria. They look sweet. Like a muscle car dash.
                    The total $$$ was about $1000 for wakeboard pro with paddle wheel, $175 for faria speedo and tach, and about $350 to have it all installed.
                    • Zwengit
                      • Mar 2006
                      • 42
                      • Costa Mesa, CA
                      Gauges for SAN
                      Have had no gauge problems with my SAN . . .
                      And judging by the hassle & cost to fix I'm real happy about that.
                      Anyone tried any Stewart Warner gauges???
                      • ag4ever
                        • 1180
                        RE: Gauges for SAN
                        OK, the '02 gauges are digital, and they do suck, but if they go out, they can easily be replaced with analog ones.
                        The '03 up are alos digital, but have an analog face. This means the signal to the gauges is still digital, but it get translated to manually turn a needle. They can also go out if something happens to the electronics, but that is unlikly.
                        The biggest failure for the '00 to '02 gauges has been the display failing, and not necessarily the ditital controls for them.
                        Just my $0.02
                        On a side note, my tach went out, and was replaced under warranty with no delay in getting the new part.
                        • Rick
                          • Mar 2004
                          • 1250
                          • San Diego, Ca
                          RE: Gauges for SAN
                          CC had a Faria upgrade kit for around 199 for the 2000-2002 boats with dead Teleflex guages. Check with your dealer I upgrade mine and posted the pictures. You need to specify whether you have PP or not . If you do the kit has a Y wire to connect to the PP paddlewheel If not they send the paddlewheel. I would think you could use the upgrade to the Faria guages for any boat as the Tach runs off the engine and the Speedo just needs power and a PW or PP.
                          Nautiqueless in San Diego
