Why is running 50 wt oil okay when it asks for 40?
  • jmo
    • Mar 2006
    • 710
    • MA
    Hey guys,
    One thing I've always been curious about is people running 50 wt oil when it calls for 40wt? why is this being done? Any down sides?
    Thanks,
    JMO
    2018 Ski Nautique 200 TE, H6
  • KTM525
    • Oct 2007
    • 126
    • Switzerland
    • 2014 Nautique G21 ZR409
    Well.. depends if you ask for something like 15W40 or only W40. With the Multigrade oil, you get a larger range to temp you can use it. A 10W50 stays less viscous in low temp and more viscous in high temperature then a 15W40. The downside, its more expensive and you don't need it. More important is: use a quality oil that meets the spec from the engine manufacturer and not something cheep. There are some difference in the additive in the oils.
    • xrichard
      • Aug 2008
      • 669
      • El Dorado Hills
      • 2023 G23
      If you read through the bobistheoilguy "Motor Oil University" pages, you might be convinced to use lower viscosity oil. Sometimes higher viscosity is recommended solely to reduce oil consumption--not a good reason, IMHO.
      Chapter One by AE Haas I think it is time to go over passenger car automotive engine oils in detail. I will be writing several articles to be published soon so I will try to get some of it out here. I feel this is a very general topic for all car owners on this …
      Previous boats:
      2015 G23
      2008 SAN 210
      2002 XStar
      1995 Sport Nautique
      • jmo
        • Mar 2006
        • 710
        • MA
        I am only referencing the operating temp viscosity, so for an engine requiring 10w-40 for example they would run 15-50.
        • jmo
          • Mar 2006
          • 710
          • MA
          Interesting read, makes me think I should run 0W-40 synthetic in my Excalibur instead of 15-40 Dino...
