2007 210 sante won't start, spring break help needed
  • gvaldez3
    • Apr 2012
    • 54
    • Pearland, TX
    • 2007 Super Air 210
    Bros,
    2007 210 sante won't start. Started quickly at the launch and ran for 15 minutes until we turned it off at out boat house. Then it wouldn't start. Turns over but but won't start. Maybe it's a relay.
  • ski4evr
    • May 2010
    • 613
    • Bowling Green, KY
    • 2005 SV 211
    Check the cutoff switch on lanyard
    2005 SV-211
    • Quinner
      • 2246
      • Correct Crafts
      what motor?
      Check Lanyard, be sure its fully engaged. Is the fuel OK or could it be bad? Add 5 gals of fresh if suspect. Inspect Cap and rotor for cracks or corrosion, if more then 4 seasons old I would consider a new one regardless. Can you hear both fuel pumps cycling when you turn the ignition on?
      • nyryan2001
        • Mar 2013
        • 1993
        • Lake Anna
        here's 25 things to verify:
        http://www.boatingmag.com/photos/25-...src=soc&dom=fb
        2019 G23 450
        2014 G23 550
        2013 G23 450
        2011 Malibu Wakesetter 247
        2007 Yamaha AR210
        • nautiques4life
          • Jan 2009
          • 696
          • SoCal
          Always check lanyard. I'd also wiggle the throttle in the neutral position... Not sure if 07 has a neutral safety switch, but on my '05 sometimes even if throttle was clicked into nuetral it wouldnt start; I'd just give it a little jiggle still in neutral and everything would work as normal. Is everything else powering up normal?
          • gvaldez3
            • Apr 2012
            • 54
            • Pearland, TX
            Thanks everybody, will it crank with lanyard off? Everything else looks normal. My boat will not crank at all if it's in neutral.
            • gvaldez3
              • Apr 2012
              • 54
              • Pearland, TX
              Typo, will not crank if it's not in neutral.
              • Quinner
                • 2246
                • Correct Crafts
                What motor? Is it keyed or keyless?
                Believe it will crank regardless if Lanyard is on or off, believe pulling the lanyard shuts down fuel only.
                One lanyard test you can do is turn ignition on, pull lanyard and then re-install, you should hear your fuel pumps cycle on re-install.
                • gvaldez3
                  • Apr 2012
                  • 54
                  • Pearland, TX
                  It's keyless and it has the 6.2 liter fuel injected motor. I'll test the lanyard when I get back to the boat this evening. Thanks again
                  • gvaldez3
                    • Apr 2012
                    • 54
                    • Pearland, TX
                    Thanks guys, it was the lanyard, put it back on and it started like a champ!
                    • hondaprlud
                      • Jul 2008
                      • 568
                      • OH-IO
                      I broke my lanyard clip once while on the water. You can reach behind and reverse the wires to finish your day if needed. I don't recommend leaving it that way.
                      Sent from my iPhone 7 prerelease
                      19 SANTE 210
                      08 SANTE 210 ZR6
                      08 SANTE 230 ZR6
                      88 Baja Ski Sport- First boat
                      • DLafont
                        • May 2009
                        • 340
                        • Gatineau Qc
                        Always fun when it is a simple free fix!! Enjoy the water!!
                        Previous: 1990 Ski Nautique
