210 SANTE 2004 ignition problem
  • bolz74
    • Feb 2015
    • 4
    • france
    • 210 SANTE 2004
    Hi,
    I'm ben from france, new owner of a 2004 210 SANTE with PCM 330 engine. It is my 3rd boat, first was a 74 ski nautique, second 90 sport nautique.
    I test the boat for the first time yesterday and after 5 mns, the engine stop and impossible to restart.
    This morning i decide to control the starter and another problem appear, impossible to to switch on ignition on the boat!!
    I try to explain:
    - switch on the battery (battery new)
    - i put the on/bilge swith in the on position
    - code on the keypad and "start", first light on the pad flash
    - "start" for the second time, second light flash, perfectpass is "on", ballast, nav lights.... all is ok BUT the gauges are "off", the fuel pump are not activate.
    I check the fuse on PME box, 2 "online" fuse near the battery, 3 fuse in the small box on the engine and i can't find a solution.
    When i push the "start" button i can listen a relay in the PME box but nothing else.
    I don't know if there is other fuse or something i forget, but my "idea box" is empty!
    If you have an idea!!
    I hope you can understand my "french english"!
  • beach
    • Jul 2010
    • 245
    • Alabama
    • 2003 SAN 210
    Did you check the safety lanyard to make sure it's fully on?
    • bolz74
      • Feb 2015
      • 4
      • france
      • 210 SANTE 2004
      Yes i check it, when it is off i can not activate the keypad
      • bolz74
        • Feb 2015
        • 4
        • france
        • 210 SANTE 2004
        Wrong connection behind the lanyard, now ignition is ok, thanks Beach, you were right!
        Now it's time to check why the starter is still not running...
