I have a 2014 210 with Pro ballast and came stock with the 1579, it's a dog getting out of the hole with loaded stock ballast and about 6 people, looking for an upgrade.
My 2011 210 has the ZR450 engine and it struggles getting on plane with the 1579. Thats with stock ballast, 600# sacks in the rear compartments, and about 6 people on board. I'm looking for more prop as well. Need to measure clearance to see if I can go with a larger diameter prop. Eric at OJ told me I need at least 1" clearance. Having said that, I don't know what prop burn is, but I'm assuming this is why Eric recommended at least 1" of clearance.2007 Malibu Wakesetter 23 LSV, 1995 Cobalt 200
Here you guys go looking for the prop. Scroll through. Just went with 1617 over the stock 1465/1579. Bust upgrade ever for my 343. Not sure with the 409 but I imagine since the stock prop is the same in the 1579, the upgrade would be as well. Diameter is really the limiting factor on the 210. I am not turning nearly the rpms I thought I would be so its actually working good on the ski side as well. Very very happy.
http://www.planetnautique.com/vb5/fo...ettleprops-comLast edited by swatguy; 06-19-2015, 01:44 PM.
Originally posted by Evening Shade View PostMy 2011 210 has the ZR450 engine and it struggles getting on plane with the 1579. Thats with stock ballast, 600# sacks in the rear compartments, and about 6 people on board.
I'm ordering my 1617 tonight. Been waiting for the feedback from Swatguy. Really disappointed with the stock prop and full factory ballast. Last week had some hard core riders out the out boat, full ballast and 8 people on the boat and it took forever to get on plane. Had to move people into the bow to get it going. Really hoping the 1617 makes a difference. I guess I'm spoiled coming from a SN200 for course skiing, I just expect the boat to pop up on plane.
Markonline, you are correct I do need some weight in the bow. Just haven't gotten to that yet. Maybe that will resolve my under propped issue. I'm not really looking forward to plumbing in a piggyback kit after all the trouble I've had with getting my rear piggyback kits to fill and drain properly. That issue still isn't resolved....2007 Malibu Wakesetter 23 LSV, 1995 Cobalt 200
I realize this is a really old thread but is very relevant to me right now.
I'm running a 2015 SANTE 210 with PCM 450 and all upgraded ballast, NSS, etc. I have a 1579 (13.5" x 14.25"). It was damaged recently and is being fixed.
Could I put a 1235 on (14.5" x 14.25") or do I risk doing something bad? Am I ok as long as there's 3/4' to 1" of clearance or is there more to it than that?
The people fixing the prop looked in their "spec book" and told me I should not go above 14" diameter.
There is a new prop that has been launched by Acme to fill the void and need for the diameter restriction on the 210. It’s the Acme 2571. It’s a beast. I’ve been through the 1579/1433/1617 and now run the 2571. The holeshot from this prop is hands down the best of all those. It’s a must for any serious wakeboarder running heavy weight.
Originally posted by uwhusky View PostI realize this is a really old thread but is very relevant to me right now.
swatguy thanks for your feedback and re-assurance. What exactly is prop burn?
I plan to run the 1235 for 3 days, at about 3 to 4 hours on the lake per day. By then, my 1579 should be fixed and I'll go back to that.
Meanwhile, I may look around locally and see if I can find either a 2571 or a 1617.
uwhusky Prop burn is what happenes to your gelcoat right where the prop blade is closest to the hull of the boat. Due to the blade being so close to the hull ( closer than the desired gap your prop dealer told you was required ) the blade spinning fast and so close will begin to wear out the gelcoat under there and thin it out in some cases all the way to the bare fiberglass. , it’s not usually an overnight event and it basically occurs from repeated use. , the prop and prop
washe basically create enough for force to “sand down” your gelcoat there. I’ve run the 1235 in the past for about 2 weeks when I dinged my prop with no signs of anything. The bad part is once you put that 1235 on therr you’re going to hate your 1579 and realize their power prop isn’t power at all. It was at the time way back when , but there have been so many props built inbetween the inception of that prop that maximize performance , if you ride with anything over factory or a big crew it’s worth uopgrading.
I did a full write up linking all the props if you do a search.
what you have to decide is this. If you do a lot of Wide open throttle cruising , slalom ski more than say 30% of time I’d definitely not do the 2571. You’ll rip through fuel at the top end there, But if you cruise lake usually at wakeboard speeds , wakeboard or surf majority of time then you’ll benefit from making that jump to 2571 greatly. Its an aggressive prop It will perform very similarly to the 1235. If you want a happy medium the 1617 is a noticeable upgrade holeshot wise over the 1579 and won’t kill the top end fuel consumption as much, but it’s still noticeably slower than the 2571 out of the holeLast edited by swatguy; 07-21-2022, 09:45 AM.
