PCM fuel injected or not
  • Robbie
    • Feb 2006
    • 14
    I have a SN 1994 with a PCM engine which i think is the smaller 290HP i was wondering if anyone new if this enging is fuel injected as i am looking to get Perfect Pass for the boat.
    Rob
  • TRBenj
    • 1681
    • NWCT
    RE: PCM fuel injected or not
    1994 is one of the years where they offered several versions of the 351:
    240HP standard 351 (carb)
    285HP ProBoss (carb)
    300HP ProSki (Throttle Body EFI)
    310HP GT40 (Multiport EFI)
    The 255HP Pro-Tec (carb) motor may have been offered in 1994 also. You most likely have the ProBoss or the ProSki TBI, but its tough to tell without a little more info. If you take a pic, Im sure it could be identified.
    1990 Ski Nautique
    NWCT
    • ScarletArrow
      • Jul 2005
      • 330
      • Ohio
      Why would they offer so many different motors in a single year?
      • bkhallpass
        • 1407
        • Discovery Bay, CA
        TR Benj,
        I do not believe the 310HP GT40 was offered until 95. ICBW. BKH
        2001 Super Air
        • jhiestand
          • 778
          • Columbus, Ohio
          • 08 Super Air 210
          Regardless of your engine, Perfect Pass will work fine (even if it's carbureted).
          '08 Super Air Nautique 210
          • Bob's2001
            • Jun 2005
            • 43
            • Lake Jackson, Texas
            How can you not know if it's carb or EFI? Have you ever opened the engine cover? The EFI looks like this. http://store.summitracing.com/largei...t=TFS-51500004
            A carb looks like this.
            http://store.summitracing.com/defaul....asp&x=36&y=11
            Bob
            83 SN 2001
            Monster Tower
            • M3Fan
              • 1034
              Re: RE: PCM fuel injected or not
              http://store.summitracing.com/defaul...;x=36&y=11
              The TBI system could be mistaken for a carb system at a quick glance if you didn't know what you were talking about. Now, the MPI system is tought to mistake.
              2000 Ski Nautique GT-40
              2016 SN 200 H5
              www.Fifteenoff.com
                • 2908
                it should have a sticker on the valve cover or hood with specs. The GT-40 was available in late 1994 when TBI stopped being offerred due to troubles. I liked those carbed ProBoss motors, very reliable and strong.
                • nautique95
                  • 420
                  • Michigan
                  • 1987 SN 2001 1994 SN 1995 Signature Edition 2005 206 Air Limited 2007 SV211 Team
                  RE: Re: RE: PCM fuel injected or not
                  The throttle body injection was not the best deal in 1994, they had their share of problems, if it isn't multi-port injected I personally would take the carb over the throttle body. IMO. The ProBoss and the GT-40 are great engines!!
                  • darrel409
                    • Jul 2004
                    • 566
                    • San Dimas, So. Cal
                    You may not need to open the engine cover. Is there an "EFI" decal on the side of the boat?
                    • cabcadd
                      • 22
                      HP's for 94 SN
                      TRBenj,
                      My 94 SN has the Carburated ProBoss and boat title claims 300 HP. I posted a question on correctcraftfan.com about engine types and HP's for this model year Nautique.
                      (http://www.correctcraftfan.com/forum...6&KW=94+HP)
                      Just curious how certain you are of the engine models and associated HP's you stated. The concensus varied but the Carb and TBI versions were both 300 HP.
                      Either way I'm happy w/mine. Runs and skis great.
                      Thanks.
                      • DavidF
                        • Sep 2004
                        • 611
                        • Austin, TX
                        RE: HP
                        I have the '95 PCM ProSki TBI engine. I never absolutely determined the HP of the engine, but believe it to be somewhere between 285 and 300 HP. The engine does NOT have the GT-40 heads. The TBI is manufactured by Holley for PCM and is 950 CFM with 4 injectors (progressive). Consequently, It breaths well and can dump a ton of fuel. Other than idling a bit rich (normal) it runs very well.
                        • cabcadd
                          • 22
                          Perfect Pass
                          Forgot to mention I added Perfect Pass Digital Pro to this my carburated ProBoss 94 and it works great. No problems what so ever.
                          • TRBenj
                            • 1681
                            • NWCT
                            Re: HP's for 94 SN
                            Originally posted by cabcadd
                            TRBenj,
                            (http://www.correctcraftfan.com/forum...=2906&KW=94+HP)
                            Thanks.
                            After a little research, I I think I was mistaken. While I believe the 92-93 Probosses were 285 HP ('92 brochure confirms this), it appears that the '94 Proboss had 300 (300+ according to the brochure). I am not sure what changes were made that added those ponies.
                            I am surprised to hear that DavidF's boat doesnt have the GT40 heads- I thought all the TBI's were the HO motors!
                            1990 Ski Nautique
                            NWCT
