No power to fuel pumps
  • brttkrz
    • Nov 2012
    • 62
    • MN
    • 1995 Sport Nautique
    So I was going to take the boat out for the first time yesterday and it wouldn't start. It is a 95 sport nautique with the GT-40. The fuel pumps won't run when I turn the key. I checked voltage to both the low pressure and the high pressure pumps and neither of them have power. I pushed the circuit breaker but it didn't seem like it was tripped. Any suggestions on where to start with diagnostics? I had the same problem 2 years ago and ended up bringing it to the dealer and they didn't really find anything. They went thought all the connections and then it worked.
  • vision
    • 515
    • NC
    • 2013 G23
    Remove and then replace the safety lanyard.
    • brttkrz
      • Nov 2012
      • 62
      • MN
      I tried that and it didn't change anything.
      • Chris Parker
        • Apr 2015
        • 7
        • Mesa Arizona
        • 2007 236 team
        Check fuel pump relay?
        • laurie8888
          • Dec 2011
          • 162
          • dubai
          • nautique 206 and 200
          And fuse
          • brttkrz
            • Nov 2012
            • 62
            • MN
            Thanks guys. Brought it to the dealer and they found that the wire was all corroded around the fuse. They replaced the wiring and put the fuse in a more visible location
