Did a compression test on my 1995 SN with Ford 351, results were all cylinders between 130 - 140 psi. Is this considered good. I guess a lot depends on the gage accuracy, at least all cylinders came in approx same readings.
RE: Compression test
All you need is a compression guage. Disconnect the main electric going to the plugs. Take out one plug, screw in the compression guage and turn the motor over a few revolutions. Take a reading for every cylinder and pray that they are all about the same.
Re: RE: Compression test
Originally posted by surroundsound64+ or - 10% or 30psi is acceptable. And it's always a little more accurate when you do it with a warm engine. You'll get lower compression on a cold engine due to blow by.
Either way, dwsa's compression is good.2018 SAN 230
1981 Ski Nautique
Sold - 2011 Sport 200V
Sold - 2000 SAN
- Apr 2005
- 420
- Michigan
- 1987 SN 2001 1994 SN 1995 Signature Edition 2005 206 Air Limited 2007 SV211 Team
how hard is it do do a compression test yourself? whats the cost of the tool(s)?
