05 210 Sante ballast switch
  • csparks13
    • Jun 2006
    • 39
    I'm running stock ballast and pumps in my 05'. The port fill works but the port empty will not. I'm not getting any power to the pump. The red light blinks on the button but no power at the pump itself. I've hooked the pump up directly to the battery and it runs. Its not tripping the fuse box under the dash. I'm thinking it has to be the switch or something in the fuse box. Has anyone had this problem before?
  • jkallen21
    • Jan 2013
    • 399
    • United States
    • 2006 Super Air 220
    Have you tired swapping the wiring to the port and startboard pumps to make 100% certain it's a switch issue?
    • gilbertnautique
      • Jan 2013
      • 32
      • Gilbert, AZ
      • '93 sport '04 SANTE
      Did you ever figure this out as I'm having a similar problem.
