Changing transmission fluid - 2002 SAN
  • youngunz
    • Mar 2011
    • 150
    • Barrie, ON
    • 2002 SAN
    Looking for some input on what is the best method for changing the transmission fluid in a 2002 Super Air. I have a vacuum pump that can be used to remove the oil, and a funnel for adding new fluid.
    Curious if anyone has any input, whether there is a plug or an access point that is the easiest to empty/fill the fluid.
    Thanks in advance,
    Brandon
    Now
    2002 SANTE
  • BrickBrock
    • Aug 2013
    • 66
    • Wisconsin
    On my 2005 SANTE with the Excalibur 330, I used a vacuum pump through the dip stick port to remove much of the old fluid and then added fresh transmission fluid through that same port with a funnel (only adding in the same volume that I had removed of old fluid). Then I checked the level as instructed in the Nautique manual.
    • ski4evr
      • May 2010
      • 613
      • Bowling Green, KY
      • 2005 SV 211
      Yep, holds 2 quarts, but best I can get removed is 1 quart. At least keeping half of it changed out regularly, is way better than most vehicle transmissions get.
      2005 SV-211
      • youngunz
        • Mar 2011
        • 150
        • Barrie, ON
        • 2002 SAN
        That's great guys. Thanks a lot for the input. I'll give it a go this morning, almost ready for cottage season. All that's left to do is a new stereo upgrade.
        Now
        2002 SANTE
