2008 230 Fluids / Trans / V-Drive
  • quaylefarmer
    • Mar 2015
    • 20
    • Lake Orion, MI
    Just started using my new to me 2008 230 (PCM 390).
    Trying to check all of the fluids but getting a little confused on the hardware that I have.
    I have read through the complete manual from Correct Craft as well as PCM but cant seem to understand exactly what my boat has.
    It has a short dip stick that looks to be in the V-Drive but the manual also calls out to check the transmission fluid via the 2 fill holes on the very front (accessible through the round inspection hole in the floor).
    2 Questions:
    Does my boat have a V-Drive + Transmission?
    If they are seperate do I use the DexronIII in both?
    Thanks for your help!
  • ScooterMcgavin
    • 1478
    • 2014 SAN 210 TE
    Yes it does have a v-drive and transmission, the dipstick is for the tranny fluid and the two holes are for the v/drive oil, and no you don't use dexronIII in the v-drive only trans, the c-drive takes a synthetic type of gear oil I believe.
    1989 Sport Nautique
    • vision
      • 518
      • NC
      • 2013 G23
      Double check the PCM manual as to whether you ever need to change the V-drive oil. I do not recall what year they stopped recommending changing the V-drive oil. It is still recommended to change the transmission oil periodically.
      • xrichard
        • Aug 2008
        • 669
        • El Dorado Hills
        • 2023 G23
        The manual is poorly written and confusing. Your boat has a separate transmission and v-drive. The manual refers to the v-drive as a v-drive transmission and this causes the confusion.
        The "real" transmission has a short dipstick--it takes dexron lll (no longer licensed by GM so you won't find it) but you can use dex/merc as a substitute. Change per the manual--I do mine at 50 hrs when I do the motor oil.
        The v-drive "transmission"
        has two plugs in the top. The fluid is not changed unless contaminated. I can't remember the fluid type--it's what your manual specs for the v-drive transmission.
        FWIW, when I got my 2008, I exchanged multiple email w/PCM clarifying this exact issue.
        Previous boats:
        2015 G23
        2008 SAN 210
        2002 XStar
        1995 Sport Nautique
        • d_nodixon
          • Sep 2008
          • 475
          • Hammond, LA
          • 2013 SAN 230
          You can get the vdrive oil from DIM I believe....it's a PCM BRAND if its the same as my 06...will take a pic and post tomorrow. My manual stated every 500 hrs or if contaminated
          2013 SAN 230
          2006 SSN 210 (SOLD)
          • xrichard
            • Aug 2008
            • 669
            • El Dorado Hills
            • 2023 G23
            I just looked at the 2008 manual....v-drive is maintenance free...no change unless evidence of contamination. Fluid: Mobiltrans SHC50. The heading for that section in the manual is "PCM Power Plus V-Drive Transmission." Which often causes people to believe the transmission and v-drive are one unit.
            Previous boats:
            2015 G23
            2008 SAN 210
            2002 XStar
            1995 Sport Nautique
            • quaylefarmer
              • Mar 2015
              • 20
              • Lake Orion, MI
              Thanks everyone!
              • quaylefarmer
                • Mar 2015
                • 20
                • Lake Orion, MI
                Is there a procedure for checking the trans fluid level (with the dipstick)?
                - Hot vs. Cold?
                - Running vs. Motor Off?
