Very cool!
This is a sticky topic.
SilentSeven - I took a Faria Chesapeake SS Black NautiqueJeff - thank you !
I exchanged the stepper motor on the oil pressure gauge today and will report tomorrow whether it works again.
Did you use this 80 MPH model (Faria 33730) so the calibration matched the factory dial?
I see there are also some 60 MPH models (example:Faria 33749) - i would guess the displayed speed would not be accurate if a 60 mph model was used.2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
His gauge is KPH, not MPH.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Originally posted by SilentSeven View PostDid you use this 80 MPH model (Faria 33730) so the calibration matched the factory dial?
https://www.ebay.de/itm/Faria-5-Spee...AAAOSwXIRcpnR6
Originally posted by NautiqueJeff View PostHis gauge is KPH, not MPH.
Originally posted by schnubbi
Bellevue WA
Pretty cool for sure ! Nice work2009 Super Air Nautique 210 TE
1989 Sport Nautique
So my 2006 220 TE speedometer gauge will work and then stops even the digital part and then maybe a few hrs later will come back on line. And repeat. If I’m reading this right and I try the fix and it doesn’t not work and I disconnect the pitot lines the digital part should still work with it disconnected. Really the only thing I want to work is the depth gauge. Thanks
Yes, that is correct.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Does anyone have any thoughts on how to get this gauge replacement kit for less than it's $900 price tag? My gauges are finally acting up and I'm tempted to make the conversion on my 2004 SANTE, but want to make sure I get the best price2004 Super Air Nautique 210 Team Edition
1994 Ski Nautique (sold)
1979 Ski Nautique (sold)
Use our PN discount (PND) for 10% off.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Out at lake yesterday.... in the morning the digital display was jumbled on the tach and the tach itself would not function. Later in the day the digital display finally came back but th tach wouldn't. Checked for loose wiring on dash and found none. When powered back up the tach needle is ticking at 0. Does this appear to be a gauge or gateway control issue?
Originally posted by schnubbi View PostSilentSeven - I took a Faria Chesapeake SS Black NautiqueJeff - thank you !
For reference: I'm fixing a 2006 SN196LE, with working Speedo and Tach, but non working Oil, Volt, and Temperature. I suspect my issue is the CAN message circuits or power circuits from the Gateway box because I purchased working used gauges from a guy on this thread and they also do not work. Mine has a paddle wheel, so no pitot tube water concern.
2006 SV211, gateway mounted under dash, no pitot tubes. Started to notice my tach LED display working intermittently the end of last season, the needle always worked, but the LED was only showing a few of the numbers/letters, alarms seem to still be working. Started it up the other day, now the needle has stopped working, LED is still failing to display properly, and temp gauge not working. Also noticed the backlights for tach and temp gauge are out, all others came on. Hoping to do a complete inspection of the wiring this weekend as suggested by a previous post but I thought I would check to see if anyone had this same issue and how it was resolved. I have owned this boat since 2014, replaced the perfect pass display in 2016 (non-gps), and a couple other gauges have acted up but nothing consistent.
Is the gateway on the verge of failure? Gauge failure?
