2007 gauge problems
  • tdc_worm
    • 532
    2007 gauge problems
    Forgive me if the answer lies in search bar...I tried but didnt come up with anything outside of the pre 2006 issues.
    I have a 2007 236 w/ Zr6. Several of the gauges have gone out, all at once.
    --Tach (to include all of the digital info)
    --Speedo
    --Oil pressure
    --Temp
    The fuel gauge, voltmeter and perfect pass are all fine. Any suggestions on where to start trouble shooting?
    Thanks in advance!
  • tdc_worm
    • 532
    I am guessing this might be a Gateway issue?
    • ScooterMcgavin
      • 1478
      • 2014 SAN 210 TE
      I had the same thing happen on my 2006 210. It ended up being a little corrosion on the connector going from gateway to the back of the tachometer, all of the other gauges daisy chained from the tachometer. I did have one gauge that wouldn't come back on. So I replaced it with a new one and all good now. Not saying this is your issue, just something to check. Also make sure the ground from gatway is good clean and solid. Make sure there is No corrosion there too. Good luck
      1989 Sport Nautique
      • tdc_worm
        • 532
        Thx for the input. I pulled the plugs out of the gateway (none of them felt loose) and replugged them in. I am guessing there was a bad connection as that solved the problem...
        • JNautique
          • May 2022
          • 4
          • Dallas, TX
          • 2007 Correct Craft 236 Team Edition
          I know this is an old post but I have an 07 236TE that all of a sudden had the oil pressure and volt meter gauges stop working. Last season the oil pressure gauge was intermittent, this year i just fired up the boat for the first time and the oil pressure and volt meter gauge are inop. Voltage gauge looks like it’s ticking a little but still reads 0. Brost cranks right up and runs just fine. Temp holds good around 170 when warmed up and hooked to the fake a lake. Can anyone point me to where the gateway is. I think i will check the connections and make sure they are clean and secure. Is that all under the dash?
          • WakeHawk
            • Feb 2016
            • 48
            • Washington
            • 2008 SANTE 210
            Best solution for these gateway gauge boats is to get rid of the gateway... Here is what I did on my 2008 SANTE 210 when I started having gauge problems:
            https://www.planetnautique.com/vb5/f...ith-garmin-mfd
