Walter V-drive
  • richard
    • Feb 2005
    • 406
    • HK
    Walter V-drive
    I need a new V-drive gear box for my 2001 Super Air Natique,since my old one generate noise inside,I want to change it, but can't find a source,DIM don't supply that, and I find rare discussion about the V-drive ,seems it makes no trouble to every body, appreciate any hints on this.
  • dave210
    • Jan 2006
    • 113
    • jax fl
    RE: Walter V-drive
    ebay has plenty of them cheap
    • DRAGON88
      • 529
      • Eugene, Oregon
      • 1999 Sport Naqutique 2005 Super Air Nautique Team Edition
      RE: Walter V-drive
      I'd try contacting Walter directly. Even if they don't sell direct they should be able to tell you where to purchase one.
      Contact info
      Edit: It looks like they also rebuild V-drives.
      Originally posted by Waltergear.com
      Factory Rebuilding Service
      Walter Machine offers a factory rebuilding service to repair and/or rebuild your Walter V-Drive. Factory professionals rebuild your V-Drive using only the correct premium original equipment marine-grade parts -- no used or inferior aftermarket substitutes are used. After rebuild, all V-Drives are run on factory test stands and checked for proper operation prior to shipment.
      How about \"Chales\"?
      RIP Nikolai (\'05 SANTE) 5/23/05 - 4/30/06
      • richard
        • Feb 2005
        • 406
        • HK
        RE: Walter V-drive
        I will check ebay to see, my location is too far or say it's not enconomic to send it to US for rebild,flight charge 2 way + rebuild = near new one? actually,all the parts inside the gear box looks fine, I become curious to find the noise how dose it come out.
        I contacted Walter,they are helping me some way.
        Thanks to all you post.
