Changing oil in 95 super sport GT 40 What filter and oil are you using ?? I think I've been using Framm PH8A and straight wait oil as the manual calls for. I'm thinking 10/40 oil would be better. What do you think?? What about the drive oil straight 30?
I'm using Mobil 1 15/50. It has high sulphur
Content needed for flat tapper engines like the Ford 351. I also use the Mobil 1 oil filter. I have seen the benefits of synthetic oils in engine life cycle testing on light aircraft engine trials and the difference is dramatic and profound compared to conventional oils.
Sooner or later your toys own you
- Aug 2014
- 380
- Salt Lake City, Utah via Texas
- 2003 Ski Nautique 206 Limited with ZR6 Engine
Royal Purple HPS 20W-50. K&N Oil Filter HP-3001Last edited by Jonny Quest; 06-07-2015, 04:06 PM.
With my previous boats I used Valvoline VR1 40wt, and a motorcraft FL1A2005 Ski Nautique 206 SE, Acme 422, PP SG 8.0, ND Tower
Prior Boats:
1999 Ski Nautique GT-40
www.skiersofknoxville.org
That’s very interesting. I had constant issues in my 06 SANTE with the oil alarm sounding when decelerating (ZR6). I called PCM and the guy immediately recommended 50W oil. I did that for several seasons with no further issues. This is good info though.
https://www.knfilters.com/hm-3001-marine-oil-filter
If anyone is needing oil filters this seems like a decent deal I ordered a few free shipping over 25$
- Jun 2016
- 541
- Ft Worth, TX
- 2022 G23, Previous: 2021 GS24, 2011 Super Air Nautique 230, 1995 Super Sport, 1983 Ski Nautique
On my GT40 I ran Delo 400 SDE and an FL1A filter. That oil meets the most recent specs. Kirklands 15w40 does too but I didn’t find that until after I sold that boat.
- Aug 2014
- 380
There are a lot of PCM small block Ford engines running with 10W-40, 5W-40, 20W-50, 15W50, 40W, etc. I don't know of any failures due to oil lubricity or viscosity issues as long as the ZDDP content is adequate. Too many folks get all wound-up around the axle when it comes to oil brand and viscosity. Relax. Run the boat.
JQ
I recently changed the oil in my 2001 GT40 and used sraight 40 weight VR1 racing oil. I looked back at the service records and noticed that the dealership that changed it last year used a 15 W 40 Rotella t4. Just for consistency, I think I'm going to change it and go back to the 15 w40. Is this the correct one and does it have enough zddp content? Is change it again worth the effort?
