Gt40 what oil and filter are you using
  • ricoshred
    • Sep 2003
    • 25
    • Unknown
    Changing oil in 95 super sport GT 40 What filter and oil are you using ?? I think I've been using Framm PH8A and straight wait oil as the manual calls for. I'm thinking 10/40 oil would be better. What do you think?? What about the drive oil straight 30?
  • Tryathlete
    • Feb 2015
    • 217
    • Lake Villa, IL
    • 1996 Nautique Super Sport
    I'm using Mobil 1 15/50. It has high sulphur
    Content needed for flat tapper engines like the Ford 351. I also use the Mobil 1 oil filter. I have seen the benefits of synthetic oils in engine life cycle testing on light aircraft engine trials and the difference is dramatic and profound compared to conventional oils.
    Sooner or later your toys own you
    • a0128
      • Jan 2014
      • 423
      • Lake Oswego, OR US
      • 1999 Pro Air Nautique
      I use Valvoline Racing 20W-50 and a Fram XG8A Ultra filter. Just make sure the oil has a ZDDP content higher than 1400. Given we change the oil every 50 hours I don't see the benefit of synthetic oil.
      • ricoshred
        • Sep 2003
        • 25
        • Unknown
        Thanks much appreciated
        • Jonny Quest
          • Aug 2014
          • 384
          Royal Purple HPS 20W-50. K&N Oil Filter HP-3001
          • NCH2oSki
            • 1159
            • Maryville, TN
            • 2005 ski nautique 206 SE
            With my previous boats I used Valvoline VR1 40wt, and a motorcraft FL1A
            Prior Boats:
            1999 Ski Nautique GT-40
            www.skiersofknoxville.org
            • east tx skier
              • Apr 2005
              • 1561
              • Tyler, TX
              Valvoline VR1 20W50 and FL1A.
              • JBird97Nautique
                • Nov 2023
                • 93
                • FL
                • 1997 Nautique
                Per PCM and a recent advisory I would not run anything above 40w as the bearing clearances weren't designed for that thick of an oil. Those that recommend 50w haven't lost their engine....yet.
Name:	Screenshot 2024-03-11 084724.png
                • jkallen21
                  • Jan 2013
                  • 399
                  • United States
                  • 2006 Super Air 220
                  That’s very interesting. I had constant issues in my 06 SANTE with the oil alarm sounding when decelerating (ZR6). I called PCM and the guy immediately recommended 50W oil. I did that for several seasons with no further issues. This is good info though.
                  • NautiqueTim
                    • May 2023
                    • 37
                    • North Carolina
                    • 1966 Mustang 2001 Air Nautique
                    I use Mobil 1 5w30 and I add some Lucus Oil zinc additive. FL1A or Napa Gold filter.
                    • Conwayfl
                      • Aug 2018
                      • 31
                      • Orlando
                      • 2018 G23
                      https://www.knfilters.com/hm-3001-marine-oil-filter
                      If anyone is needing oil filters this seems like a decent deal I ordered a few free shipping over 25$
                      • hal2814
                        • Jun 2016
                        • 541
                        • Ft Worth, TX
                        On my GT40 I ran Delo 400 SDE and an FL1A filter. That oil meets the most recent specs. Kirklands 15w40 does too but I didn’t find that until after I sold that boat.
                        • Jonny Quest
                          • Aug 2014
                          • 384
                          There are a lot of PCM small block Ford engines running with 10W-40, 5W-40, 20W-50, 15W50, 40W, etc. I don't know of any failures due to oil lubricity or viscosity issues as long as the ZDDP content is adequate. Too many folks get all wound-up around the axle when it comes to oil brand and viscosity. Relax. Run the boat.
                          JQ
                          • SAN4Fun
                            • Jul 2023
                            • 26
                            • Simpsonville, SC
                            • 2001 SAN 210
                            I recently changed the oil in my 2001 GT40 and used sraight 40 weight VR1 racing oil. I looked back at the service records and noticed that the dealership that changed it last year used a 15 W 40 Rotella t4. Just for consistency, I think I'm going to change it and go back to the 15 w40. Is this the correct one and does it have enough zddp content? Is change it again worth the effort?
                            • Scooter G
                              • Jan 2022
                              • 1322
                              • On a Lake in Idaho
                              • 2022 G23 ZZ8
                              Seems a fair price for a K&N filter Conwayfl, and looks like they are still running at the sale price.
                              I run K&N's on all the 2 & 4 wheel toys, never thought about the boat. Thanks for the share.
