2001 sport/air GT40 engine trouble
  • Franciz
    • Sep 2013
    • 44
    • N.C
    • 1988 ski nautique Current 2001 air
    GT40 starts and immediately dies. I mean fires like it should tacks up and immediately cuts off. After a couple of tries it will start like nothing happened.
    Any suggestions?
  • Tryathlete
    • Feb 2015
    • 217
    • Lake Villa, IL
    • 1996 Nautique Super Sport
    Lots of thoughts, since mine is doing the same thing. Any air that gets into the system will do this, and I've bled the air out at the test port and sometimes that works. I'm in the process of looking for loose hoses....big cause, replacing the cheap $10 relays for ignition and fuel pump. If I don't find leaks, I'll look for loose electrical connections near the battery and then replace the low pressure fuel pump....which many have told me is their cure. Confused? I know I am.
    Sooner or later your toys own you
    • jhersey29
      • Nov 2013
      • 330
      • Colorado
      Check the driver ejected safety switch. Disconnect it on the back and put the 2 wires together or use another piece of wire to make sure it has a complete circuit.
      • Franciz
        • Sep 2013
        • 44
        • N.C
        I replaced the relays, plugs, wires, fuel filter(SOB to remove the can), and have been playing with the kill switch. I've had no luck as of now
        • jhersey29
          • Nov 2013
          • 330
          • Colorado
          Fuel pressure check would be next on the list. Quick and easy with an inexpensive pressure tester available at any automotive shop.
          • east tx skier
            • 1561
            • Tyler, TX
            Are you tripping a breaker when you do this? If so, might be the fuel pump. Fuel pumps usually don't die intermittently, but mine did.
