05 SANTE Replacement Pump
  • Nick Heimer
    • Apr 2015
    • 69
    • Omaha, NE
    • 2005 SANTE 210
    I'm wondering if anyone has suggestions on a replacement fill pump for the rear ballast?
    My starboard side is dead, and I'm thinking I might just replace the port as well. Not sure if I should go Tsunami 800GPH, upgrade to 1200, or try a Johnson?
  • obd666
    • Feb 2010
    • 793
    • Bostian Heights, NC
    • 03 SANTE
    i changed mine out several seasons ago to rule 1100's and have been happy with them. i had to change out the mounting brackets too though, so you might stick with one that uses that same mount for convenience.
    2003 SANTE - "OG 210"
    • a0128
      • Jan 2014
      • 423
      • Lake Oswego, OR US
      • 1999 Pro Air Nautique
      The Tsunami 1200 will have 1 1/2" inlet and outlet whereas the 800 has 3/4" If you go the 1200 route you will need to come up with some reducer fittings to accommodate your existing hose size. The Rule 1100 uses 3/4" connections so it may be a better fit than the Tsunami pumps.
      • jkallen21
        • Jan 2013
        • 399
        • United States
        • 2006 Super Air 220
        you sure it's dead and not just stuck? If you're not sure, swap the power from starboard to port and see what happens.
        • Nick Heimer
          • Apr 2015
          • 69
          • Omaha, NE
          • 2005 SANTE 210
          Thanks guys.
          I did try the power swap with port side. When I pulled it apart it was pretty gummed up and didn't move very well.
          I think I'm going to order the Tsunami 800, just for the sake of convince. It looks like it should mount the same and work with all my existing fitting. Only $25 on wakemakers right now.
          • obd666
            • Feb 2010
            • 793
            • 03 SANTE
            good call, should work fine for you.
            • cguse13
              • Aug 2012
              • 96
              • Broken Arrow, Ok
              1 of the pumps on my 05 had to be replaced last year. I ended up doing the same thing just purchased the 800. I did take the money i saved and bought a couple extra quick connects and put them at the pumps so i could use the pumps on either side if one quite working by switching the hose
              2005 Nautique 210
              96 Mastercraft Prostar 205
              94 Malibu Euro f3
