Dead Faria Tach
  • Treybizttu
    • Sep 2014
    • 345
    • Grapevine
    • 99 Super Air Python
    Dead Faria Tach
    LIke the Title says. I have a Faria Tach/Hourmeter Combo that the tach no longer works at all. Hasn't bounced or moved an inch. The hour meter decides to be on every once in a while but not consistantly. Everything in the back appears to be hooked up as it should and the connections are clean.
    Are the faria replacement gauges sold for nautiques just their standard gauges in the correct size and application? I.E. I can just buy a tach right?
    Anything else I should check but I dump the money on a tach?
    Thanks!
  • DW SD
    • Mar 2015
    • 416
    • San Diego county
    • 2001 SAN 210
    You can also send to North Hollywood Speedometer (or other speedo shop) and they will repair.
    I've had them build custom gauges for various applications. Great shop. Good turnaround time. Especially if Grapevine means southern california.
    Doug
