2002 SANTE - Ballast Switch Problem.
  • LOWbook
    • Apr 2013
    • 7
    • United States
    • 2002 Super Air Nautique Team Edition
    Filled the tanks this weekend with no problem then when I went to empty, the switch would not light up/come one. The fill switch does the same thing. Does not light up/no response. Any ideas before I just start messing around with it? Has anyone seen this before?
  • nukemustang
    • Sep 2014
    • 410
    • Summerville, SC
    • Current Boat: 2018 GS20
    If you can check for voltage on the back of the switches, check the distribution point (breakers tripped?) and start there. If there is no power for fill or empty, it is a common problem.
