I have a 2004 210 and one of my ballast fills up while its in the closed position. How do I fix this? Also my gauges are not accurate. Is there a way to fix all three of those?
Not sure if your boat has a separate intake valve for the ballast system but on my 2000 SuperSport I had to replace the brass intake ball valve that filled my factory ballast tanks. It would not close or open completely and allowed water to get in and fill my tanks when it was supposed to be closed.
Same problem on my 2003 SANTE. The port side will fill on its own. I will try to find it myself but if anyone knows exactly where it is please chime in so I can save myself some time.
If they are the original Flow Rite valves, this is a know problem from wayyy back...
http://www.planetnautique.com/vb5/fo...ballast-valves
this is a 16 page thread that details the issues with these valves.
Tim
Had the same issue with my 03 SAN. I ended up taking out the helm control valves all together. I replaced both seacock valves and found one to be in pretty bad shape. Once I replaced the seacocks the problem went away.
I have the same problem with stbd valve. Anybody know what size? I saw some at West Marine that looked very stout.
Sent from my iPhone using Tapatalk2005 Air Nautique 226
Supra Comp (prior)
Originally posted by BoardSkier View PostI have the same problem with stbd valve. Anybody know what size? I saw some at West Marine that looked very stout.Last edited by factive; 06-22-2015, 06:32 PM.
